such as http://www.overclockers.co.uk/showproduct.php?prodid=CB-031-AK when using 2 x 120mm fans in push/pull config on their cpu cooler?
I'm planning to use 2 pwm controlled fans for push/pull on a corsair h50 but my MB only has one pwm fan header so I was planning on using this splitter...can anyone tell me if they have used a similar set up and if so did they experience any problems or did things go smoothly? How does the MB report the fan speed when there are 2 fans running from the same fan header?
This is my first post by the way...please be gentle with me
Jack
Jack
