Does auto detect clock settings work??
27 Nov 2003
Loughborough
Hi,
In the Nvidia tab (aftyer Coolbits) does the auto detect clock settings work for memory and GPU??
I'm not going to trust them but wondered how accurate they are. They suggested a change of the following -
From 370Mhz -> 422Mhz
From 1.05Ghz -> 1.15Ghz
I'm just curious if its right at all?
Whoop :)
Hi Whoop :)
yes ,
Should be fine.Overclocks both GPU and ram.
Run a 3d mark and look for artifacts etc.. and play a few games see how you get on.
i'm under the impression that thats not a Radeon 9550 he's overclocking. Never seen a radeon 9550 with 1.05Ghz memory lol
Mul
Personally I find it better to do things manually. Autodetect usually undercalculates the overclocking potential of my cards.
helpimcrap said:
nor a radeon made by nvidia. :p
Lol :p
Hi all, (Easyrider :) )
The one in my sig needs replacing but I keep forgetting, its Kingpin: LOC plus my MCE machine spec. :o
The machine at test at the minute is -
AMD Athlon XP2800+
2Gb Corsair Cas3 PC3200 (purely for Bf2)
Nvidia 6800GS OC
So the auto detect is more likely to underclock than overclock hmmmm?
I still need to do try a pipe unlock too, but 3dmark 03 default settings gave me -
9885 Marks @ stock 370Mhz/1.05Ghz
10478 Marks @ 400Mhz/1.10Ghz
I haven't dared do the 422Mhz/1.15Ghz in case it was potentially damaging.
Do I seriously have to sit and watch it for artifacts for however long it runs each time too :o
Whoop
It's highly advisable, especially using auto-detect, when I used my GS, coolbits would jack the memory speed up way too high and artifacts would always start to show after a bit. Better to watch whats happening rather than toasting your card... :D
Just did 420Mhz/1.15Ghz - 3D Mark 03 score is now.... 10810 :)
Didn't watch EVERY single screen but did keep my eye on it, seems clear enough to my eyes :o
The temps seem fine so I don't know if I should go higher or leave it at that, what setting would I be best leaving it at full time? Stock or one of the others. :)
Its a BFG by the way.
EDIT - 1000 extra marks from stock, is that normal these days??
EDIT2 - Emlyn_Dewar what did your GS get to by the way?
Whoop
