- 7 Jul 2009
- Newcastle/Aberdeen
No, bends increase water speed. Friction is irrelevant, since it's a force present in the whole loop. The water goes round the corner, but it doesn't stay in the same orientation, if you understand this. It stays more to one side, and spins a little. This is due to centrifugal force. You know when you spin a bucket of water around your head on a rope and the water stays in the bucket? Well that's because the centrifugal force is greater than the forces around it, namely mavity. The effect is similar to that of a point bar in a stream. At least, this is my understanding. Also, you pointed out that the water speed would increase when going through a confined point, this is part of the same principle. Forcing it to take a different path increases the speed of the water since the flow of water still coming from behind remains the same and so the water must speed up because of the increased pressure. And most water blocks are narrower than the tubing, so the speed would increase here as well.
It is possible to do water cooling without a pump, but since the water will be moving significantly slower the temperatures will be reduced due the water only being propelled by convection, which means that it has to get hot before it can move on. With a pump though, the differences in speeds don't matter much because the flow of water coming from behind a single point in the water will always be the same.
At least, that's my understanding of the principle, i don't know if it's entirely true but it makes sense in my head. I do know however that water speed increases while going around a bend, so everybody's concerns that bends and constrictions in the loop will reduce water flow are meaningless. I also know however that after a certain point water speed is irrelevant to the temperatures, and if the water moved too quickly i assume the temperature would rise since it wouldn't get enough time to transfer hear energy from the CPU or other components to the radiators.
