- 28 Jun 2005
- Behind you
Hi,
Just got a 840 Pro 512gb SSD. Used the migration software and then installed the SSD and all is fine
Not sure if installing the Magicion software makes any difference in any way. Did you install or leave it off?
Ta
Not sure if installing the Magicion software makes any difference in any way. Did you install or leave it off?Ta
