Does Solid tubing Increase Pump noise?
15 Feb 2013
Edinburgh
Hey
I was wondering if anyone who uses solid tubing could tell me, Does using solid tubing increase the pump noise?
I was thinking it would as the vibration would travel down the tube and the pump wouldn't be able to be isolated by sponge etc.
Personally I'd be more inclined to think that the rubber o-rings in the fixings would provide a dampen any vibration transmitted down tubing
Rather good point on the O-rings :) I have some small rubber dampeners on my bow to take the vibration out of the limbs could consider sticking a few of those on the back of the pipes hidden. If they can stop the limb vibration they'll handle a pump.
Side note:battfink I am so jealous of your system :D
