Does this exist? (Wireless USB extender)
4 Jan 2005
My mouse is quite a ways away from the base unit itself, and I was wondering if there were USB extenders but of the wireless variety. Now I know what you're thinking - 'buy a wireless mouse you bozo', but I love the G400 I'm currently using. It also goes for the 360 controller and various other USB devices I use every now and then.
Basically I'm after a sort of deal where the USB wireless receiver is in the USB slot on the PC and the other end is on the mouse cabling. I'm finding it hard to find anything like that.
The 360 controller has a great range. As for the mouse.. you could try looking for a 2.4Ghz mouse, that would have a much longer range.
Bluetooth has a massive range if there is line of sight, but put anything at all in the way and it gets into trouble, i have used a keyboard 50 meters from a machine but it does not work well if you put the receiver under the desk 1m away
