Does this motherboard and processor work together?
9 Oct 2012
Hi im looking at a MB and a CPU and i dont know if they will work together. Please can somebody tell me.
MB : Asus M5A78L-M/USB3 Motherboard
CPU : AMD Athlon II X4 641
Thanks
Jeremy
Yes the parts have already been bought. (I was not the one buying them i just put a basic spec list together so the person could get the idea for the price, I wasnt expecting them to order it right away...) They have not arrived yet.
Then I guess you have to try it and see what happens.
Do you have a backup CPU just in case?
It shouldn't work, the Athlon X 4 641 is a Llano based chip, on the FM1 socket..
You have picked A AM3+ motherboard...
Its down to AMD's silly naming.
No i dont have a backup CPU. How will i work out if it is the CPU that the problem and not the MB or something else.
You cant really.
The board may seem to power up with the fans spinning but no other activity.
It may not do anything at all when you power it on.
It may work perfectly as the CPU is supported but just not listed on the CPU support list.
And there's your answer.
