hatake said:
I get what you’re all saying but I’m still not really convinced that all the qualities in a high-end case can’t be found in some of the lower-end cases. I’m definitely not claiming that I’m right and anyone who disagrees is wrong and wasting their money, I just want to see what other people’s opinions are and maybe get a debate going (part of the reason why forums are made).
And this is a debate, so dont worry
![Wink ;) ;)](/styles/default/xenforo/vbSmilies/Normal/wink.gif)
and to quote myself I said:
Alu_ATC said:
There is nothing wrong with cases below £100, infact, if you want a budget case like your X-Blade, then go for it! The arguement here isnt whether or not cheap cases are good, but I can't believe you actually think a Jeantech Phong is going to be as good as a Silverstone TJ05 - they are a different range of cases - its like cars on a smaller scale, and some are going to want something that is just fuctional, like yourself.
As I said, there is nothing wrong with buying budget if thats what you want. The argument is about the merits of high end over budget, and that reminds me, you didnt answer my question - how many high end 'dud' cases have you owned, or even high end to make this comparison? From what you've said I doubt you'd buy an expensive case, so your not likely to have owned one and experienced one.
hatake said:
Just to comment on Alu_ATC’s first post, I did say I agreed that a quality PSU is worth the money, but that doesn’t necessarily mean that you have to swap them out with cheaper cases or that I intended to.
If I bought the Antec SLK3000B, which is a good case without a PSU, it only costs £30 and I can choose my quality PSU. With the mentioned Antec Sonata, I wouldn’t say it was totally high-end price-wise. Although a touch pricey compared to others, it does come with a quality PSU unlike others.
Its a touch pricey because it comes with a decent PSU, that makes sense right? If you went for the Antec Sonata, that is a good case - and Antec is a brand name. Some will buy it just because they are an Antec fan, which is fine if thats what they like. But its not an 'unknown' brand like the other cases you are comparing the high end to.
hatake said:
Cases like the Lian-Li V1000, £140 and there isn’t a PSU. Okay, they are a little different in type, but are the features available soo different from others that it merits such a large difference in price?
Bit of an understatement there, 'a little different in type'. First of all, design wise, yes it is very different, take a peak inside one. Its made of quality materials, and is built superbly well. Dont believe me - fine, go find one and have a look for yourself, then tell me that a £10 - £30 has anything close to the quaility of the Lian Li.
hatake said:
Fair enough, I didn’t consider the fact that you can sell the case on again for a similar price, but if it were that good a case, I wouldn’t expect to sell it for years to come, if at all. If I were going to change it, there would be some reason that meant my case is redundant or insufficient, thus little re-sale value.
Ok, so you wouldnt sell it for years to come, thats your choice, but in years to come, it will still keep its worth (most likely). Just because you wouldnt sell it on doesnt mean it wouldnt have any re-sale value! It does have re-sale value, it you choosing not to sell it on. Thats a personal choice again, and no refelction on the case.
hatake said:
And to comment on Yewen’s post, an expensive case doesn’t guarantee less noise. Yes, it is less likely, as the real cheap cases tend to have more resonance in them, but you’ll find that some high-end cases aren’t without their own vibrating parts.
We all know that the high end vibrates as well, most of the time because the cases are made out of aluminium. There are ways to get around this and its the type of material that is used that causes this to happen. Its like having a car, no matter how well made and 'luxury' your still going to hear a bit of engine noise.
hatake said:
Such as the Antec P180, there were many complaints that the plastic bracket that held the rear fan on vibrated badly (not to mention the numerous complaints of the door getting warped, not something you expect in a high-end case).
Yes, your right. I dont partically like the P180 and these are manufacturing faults that need to be address. But these are the only 2 niggles I have heard of in this case - if you really dont like it, you could sell it anyway
hatake said:
The amount of noise generally depends on type of components. A 60mm fan is going to make much more noise than a 120mm fan. A 5400rpm laptop HDD is going to be quieter than a 10,000rpm Raptor. A loud HDD can be sorted by buying real cheap grommets or suspended with elastic, and I've heard people using cable ties to attach fans instead of screws to reduce the noise.
Yes, and most cases that are sold with fans that are high end have decent quality fans. They are mostly changed out either when they get old, or when people want something like LED fans. The fans that come with the cheap cases also have to be factored into the cost, so once you taken into acount the PSU, fans, overheads etc... that case isnt going to be made of a material that can be much cop can it?
hatake said:
So I still believe that brand name plays a large part in cases and cheap ones can be more than suffice. And I back this up by the fact that Alu_ATC said, “with a name like X-Blade, do I need say anymore?”
That just implies it is a bad case due to a bad choice of name. The X-blade is not as bad as he made out; it is an excellent case for the price, it takes 3 120mm fans(possibly tacky but you already own fans that you can use), has ample room for expansion, cost him less than £40, made of steel so sturdy, little or no resonance, and has a 400W PSU. The first link that came up on google (
http://www.overclockercafe.com/Reviews/cases/X-Blade/index.htm) rated it highly, complimented the "cheap" paint job, and recommended the case. And unlike the P180, the door maintains its shape and closes.
If you believe that the only reason I didnt like the X-Blade is because of its name, then you misunderstood me I'm afraid. Previous to this I stated my arguements as to why it is not a terribly good case. Who are you trying to convice that the case isnt as bad as I made out? Like you, I have seen this case and used it before, and having owned some high end cases myself, I know and can tell the difference.
As for the fans it comes with (which by the way, is a 120mm fan and two 80mm fans, not 3 120's)- just becuase you have fans laying around that doesnt mean that everyone does, and this again something that has to be bought ontop of the basic price. Ample room for expansion? In what way? Your temps are going to get a lot higher if you've got more than 2 Hdd's. This is just an example, but there is no room for eATX if you wanted it. The steel is of a lower quality than you would find in a lot of the higher end cases. It also has a lot of sharp edges on the inside.
You are showing one review, which takes into account things such as the price in comparison to the quality. They have done thier job, its a 'good case for the price'. For £40 its not bad, but if it was anymore expensive it would be overpriced, as other more expensive cases are better.
hatake said:
If X-Blade had the name Antec or Silverstone slapped on it, I recon he wouldn’t have slated it so badly, probably would even have said it was good.
If you really believe that then you are again mistaken. You believe my only arguement is its brand name? If Antec or Silverstone was slapped on it, i'd wonder what the hell they had done to their designs and why they had produced such a case. If you think I only rate case on brand, perhaps you should read some of my other posts
. I bought a CM 530 this Xmas for a friend, and it seems a pretty good case. As for Silverstone, I think some of their designs could be much improved, and I dont like every high end case I see. For example, Im not a big fan of the 3D Aurora (sp?) or the Antec P180.
I honestly dont know why you are still talking about brand name, lets get this straight - Antec etc is a brand name, a case that you were praising earlier. Are you talking about no name budget brands, because that is different. Remember, you can still get cheap cases from large high end manufacturers.
I can see the benfits of a expensive high end case, as well as that of a budget. Where we disagree, is that you think a cheap £10 - £40 case can compare to likes of a V1000, TJ03 and 110-SX1.
Dennisthemenace said:
My point exactly. There are dud cases in the high end market as there are in the cheap low end market, and some excellent ones in both markets. One point that i found when buying cases is the extortionate prices paid for some of them. The cost of making a steel box the size of a computer case is probably less than £10 a hit, yet some sell for over a £100. The small volume produced by some unheard of case maker at lower prices does not always equate to to a pile of junk, and a few can be classed as high end in their own right.
Just like a pair of trainers, i buy the best, and the best doesn't have to have a silly tick on them.
Your right that there are some good cheap cases, and some overpriced cases that arnt so good. Your also right that there are some excellent cases in both markets. But please name some 'dud' high end cases. Also, instead of guessing, maybe find out how much it cost to manufacuter a case such as the Lian Li V1000 and then how much it cost to produce the X-Blade. Both have to make a profit to stay in business, but are you telling me that they both cost THE SAME amount of money to prduce, and one is jacked up a lot higher?! The X-Blade probably did cost about £10 to produce, but I think the V1000 will be more. A smaller generic or no name brand wont work in the same way as companies such as Antec, Coolermaster, Lian Li etc...
Which generic case have you heard of that is high end in its own right? I want to see it! Please post it here and we can all have a look.
You dont like Nike, nor do I at all, but cases arnt the same as trainers unfortuantly, and you get what you pay for.
*Yawn*, wow, a lot of typing, I need some lunch!
