Hi,
Just putting together my new system with a Asus P7H55-M board. My question is about the 8 pin power socket near the CPU. For some reason there's a small black cap over 4 of the pins (see attached image). Do I just remove it and plug in the 8 pin cable, or is it telling me to use the older 4 pin cable in the 4 open holes. The cap just clips right off if you pull it, but I can't figure out what it's there for.
Here's a close up view of the cap on half of the 8 pin power connector-
Thanks in advanced
Simon.
Thanks in advanced
Simon.
