- 9 Jul 2008
- Bristol
920 sounds good
and is cheaper
Cheers for explaining guys![]()
@ sldsmkd your not being rude, should have really had a look, but at a quick glance (only had 10 mins lunch left) i couldnt tell a difference, i guess the other 920 is CO stepping?
Glad you didn't take it the wrong way. Just trying to say that if your gonna watercool you will have to spend a lot of time researching individual components, and it's a lot more expensive, prone to errors and all around difficult than air cooling
I'd suggest picking up a nice watercooling case, such as the Silverstone TJ07, bung an i720 in it and start on air. You can always start watercooling later.
Main reason for returning to this thread was to point out that the 6 core i7 chips are coming out eventually. I'm probably going with a 920 D0 then upgrading to a 6 core once they're out.
