Hi,
After my requests most of the day for JS code for vertical drop down menus I discovered the easiest way to tackle my task was to infact start again and you CSS and HTML only....so I did , heres the results:
Click here
BUT , yes theres always one of those unfortunately......
FF is not displaying it like IE6.....
As ive only used CSS and HTML I wonder if an expert could tell me why FF is not displaying it the same way as IE6??
Thanks in advance
Cheers!!!
Click here
Thanks in advance
Cheers!!!
........Im learning loads and using a CMS would mean the end of learning which I dont wanna do...its my first site
