Don't have a drill.. Sds drill?
21 Jan 2010
Cordless drill through brick? most cordless drills I have had barely touch the surface of a brick.
Enter the 21st century, they are light years ahead of where they were. I was messing about with a gifted Dewalt of 8 years vintage - useless. Upgraded to a brushless M18 milwaukee and the thing goes through brick light butter.
OP - a new cordless, Milwaukee M18 in kit, would be a god send in general. Don't do what I did and upgrade AFTER most of your major jobs are done :D
I did however get a wired SDS for two reasons:
1. I needed to drill a 6" hole for an extractor fan through 2 layers of brick
2. I replaced some fence posts and chiselling the old fence-crete out was a right ball ache. I got an SDS with Chisel action.
Think I paid £99 quid delivered and £18 for a pack of bits from Amazon. Makita.
I almost bought the cordless Milwaukee M18 SDS but I understand they are still a million miles off a corded SDS. So corded all the way for SDS.
Edit: key point is if you do get an SDS double up and get one that can operate as a chisel too. Super useful for removing tiles/breaking concrete up. But it certainly isn't an everyday drill.
6 Dec 2005
Cambridge, UK.
Yup - with hammer function I should say. Like I said, I had a SDS corded that I used now and again but after getting the milwaukee M18 as a few others mentioned above, I never ever used the corded again.
If I won the lottery tomorrow, I’d fill my Dream Man Cave with the entire M18 range.
Hah, I have a lot of milwaukee kit.
21 Jan 2010
:D absolutely. My Soniworx from donkeys years ago was playing up. Opps.... better pop off and get the M18 multitool... Random orbital... well I may as well put the extra 20 and get the M18 RO. Typically hate buying into a particular eco-system but so far it has been a joy!
Edit: OP, this was the SDS I mentioned. It has chisel and drill so serves all the purposes in my original post. As others have said, you need the special SDS bits and it isn't an everyday tool.
https://www.amazon.co.uk/Makita-HR2...d=1&keywords=makita+sds&qid=1614181956&sr=8-5
This is the Milwaukee we are creaming over:
https://www.screwfix.com/p/milwauke...-li-ion-redlithium-cordless-combi-drill/451gf
I think I paid £230 but it included another battery and the impact driver.
7 Dec 2012
Gloucestershire
I bought an SDS for getting up a tiled floor, about 4 years ago. I've only used it for drilling twice since then (and only used one other time - for breaking up the concrete under a fence post).
A combi drill is all you need for drilling into bricks, generally.
18 Oct 2002
Sandwich, Kent
A basic cordless hammer drill will go through virtually anything in a typical household. SDS is only really required for very heavy duty jobs - and for a DIYer, overkill.
Trying to drill through masonry without a hammer function will just overheat and blunt the drill bit.
Oh, and this worked fine. It's more about the battery capacity than the drill power - I just ran it on the lower gear.
17 Nov 2015
Northants
Decent drill bits with a cordless hammer drill should be fine for anything short of core drilling.
I use the Bosch Multi material on a Ryobi One+ Hammer Drill and they fly through almost anything. Just don't be an animal and burn them out.
https://www.screwfix.com/p/bosch-straight-shank-multipurpose-drill-bit-set-4-pcs/95958
Only use the SDS for 25mm upwards or if I'm using it to break up concrete. I have the Titan one and it weighs a ton if you are up a ladder trying to drill a hole. It will also snatch, whip around and crack you in the face!
7 Jul 2003
Chelmsford
Cheapo Titan one in screwfix.
It’s heavy, but for occasional use it’s awesome.
This 1000%.
I bought this one to drill through external walls for ethernet cable.
Goes through brick like a knife through butter.
The one I bought that included 22 bit accessories isn't in stock, but this one is https://www.screwfix.com/p/titan-tt...us-drill-9-piece-accessory-kit-230-240v/97533
Yes it's heavy and I wouldn't want to use it all day, but for occasional use it's brilliant.
If you haven't got any cordless drills, then get the SDS and a decent 12v drill/driver (Milwaukee/Bosch/DeWalt/Makita) and they will be suitable for almost anything you need.
5 Aug 2013
Shropshire
I think that what people don't realise is there are bricks and there are BRICKS - The FIL had a council house and even with a electric hammer drill he would wear out a drill for each hole - Use a SDS drill and it was fine - - I have electric drills and 18v battery drills but if I am drilling hard bricks or concrete the cheap Lidl SDS drill is the one to go for - it also has a standard chuck with the kit.
Everything depends on the hardness of your bricks and I think a lot of people today haven't really come into contact with very hard engineering bricks or the ones used in my old house on gable end buttresses that had been fired a few times.
The outer brickwork on my 1972 bungalow has very hard bricks so SDS every time.
The Titan above is over kill - just get a SDS that looks like a normal electric drill.
My Lidl drill is same as this.
http://offers.kd2.org/en/gb/lidl/pgiKi/
22 Nov 2017
I would recommend buying an SDS to supplement a combi. Bought our second (as in second lived in house I don't have two!) and often found the combi would struggle on our walls, not all but some. Bought an SDS and it has made my life so much easier. I bought into the Ryobi brand and I think the One+ SDS was somewhere between £60-£100. I get that not everyone can or wants to spend that sort of money on a tool but it's such a miniscule fraction of the cost of my house I can justify it. The Titan set above looks like a bargain for the average DIYer.
The combi does most jobs but it really is handy to have.
I have been expanding my tool range and if I was buying from scratch I do wonder if I would prefer a nice 12v hammer drill combined with an SDS as the light weight is appealing. Tempted to get myself a Bosch or Milwaukee 12v drill, the GAS is painfull!
27 Mar 2013
I tried hammer cordless on my bricks and gave up and broke out the sds. This was an 18v bosch, not some poxy little thing. My bricks are quite tough, as I bought a challenge sds drill years ago for doing a tumble drier hole (105mm or something like that), the drill had flames coming out of it before I'd gone halfway through the brick.
9 Nov 2008
I've got one of those Titan's from Screwfix and it's brilliant, it'll take down walls and hang pictures. It's heavy and noisy but I only use it a few times a month so who cares? Excellent value and with lots of handy bits.
Deleted member 66701
D
Buy an SDS AND a good quality cordless hammer drill.
It's all about the right tool for the job - sometimes that's an SDS, sometimes a cordless.
Get a cordless impact driver as well while you're at it. You can thank me later.
15 Sep 2008
That poor drill! I wonder how much life it's clutch has left if you were coring with it. Brave man though, I much prefer having the power for that kind of job.
y4mxhfBM3qUbEk_zuqqWPtuULST5zrGMH0jwQ1UXjhZnWdt-NYGbZXIl0FvdQaMYvu3crlQvtXqbIxh4rw5eZ0nPqth-lty21zL9uAF1ZConTxX6DMjhrrF5fmWPhUl00UmqTIlLV5Ng2f8eTqGHBiFi25hZbfLh9tpI7A-E5wlo_cDhKkwYYzpB8nQI_YVXj_W
I agree with many that a good cordless combi will satisfy most diy'ers and small jobs around the house, but there'll be times when you're farting against thunder with the wrong tool.
