- 18 Jan 2024
- Ireland
Haven't noticed Micro stutter but have settled on mfgx2, DLSS4 quality and PT off. I can notice weirdness with mfgx3 so no PT for me until I get a 5090
I assume DLSS4 is built in and you don't need to use latest or preset k via Nvidia driver. I have opted for DLSS4:quality anywayIt's a DLSS 4 game, don't need to be using Quality mode when your output res is 4K, use Performance for the fps uplift. Visually it will essentially look identical even in motion. With DLSS 4 you can almost forget everything from past upscaling mode experiences as they don't really apply any more. Preset K (Transformer model) is excellent.
I was playing Dark Ages on a 4090 with PT and 4K output with 2x FG without any issues. Reflex handles any latency concerns in this implementation.
Thanks for the tip. Only have Space Marine 2, Diablo IV, and Doom Dark ages installed at present. All support DLSS4 natively now after recent updates, and reflex ( have to turn on mfg for reflex to work in SM2 though). I turn on v-sync globally in driver (never in game). and the LG C4 is g-sync compatible. Only set frame limit 3 frames below max refresh if gane not supporting reflex. Zero tearing, microstutter or coil whine to date. Generally use DLSS quality.If the game shipped with DLSS4 support then yes you don't need to do anything, it's only with games that originally did not ship with DLSS4 where you need to tell the nvidia driver to use Preset K, can be done a number of ways but the simplest is via DLSS Swapper app which handles the presets etc fully.
Here is my DLSS Swapper view for example:
It's path tracing and full hardware RT, there is only one GPU vendor where it's going to run properly on currently and it is highly optimised.
