Doube clicking on a Hard Drive in My Computer..
A2Z
A2Z
9 May 2005
Earth
Doesnt do anything!
It should open it up but nothing happens, i have to right click > explore to open it.
XP
Anyone have any idea?
If you wrong (right) click on the drive icon, what action is BOLD (default) in the drop down menu?
If its anything other than 'Open' then you might need to run this little Reg Patch... 'Start/Run' then 'regsvr32 /i shell32' (with out the markers.. but note the Spacing!!)
I've heard it work for the majority!, but I've not had to try it!! :)
ahhh
'AutoPlay' is in bold :confused: dunno how that happend
tried the reg thing...but didnt make any difference
You've not got an autoplay.inf file in the root of the HDD have you?
i did do some research and the idea of a trojan or something, putting an autoplay.inf file on the HD came up, can you remind me what the root directory is? :p I did search for the file on all 3 HD's but there was nothing
I know of a virus that does exactly this. Have you done an AV scan?
I havent had any AV software let alone done a scan in years :p i doubt it would be a virus but ill do a scan anyway
just to let you guys know how i fixed it...i ran the housecall thing it did find a few things..but didnt seem to fix it..although FF crashed half way....then i downloaded a prog called Flash Disinfector which fixed it
thanks for the help
