- 2 Jul 2008
http://www.gigabyte.com/products/product-page.aspx?pid=3768#
Hi Chaps, I'm looking to make my first mATX (none overclock) build by downsizing from my current rig. I want to use the attached mobo as its cheap, and got usb 3 and sata 6/gps etc. Also I will use onboard graphics so already I can sell my noisey graphics card. I just need some pointers on the following...
1. Will the current memory & cpu work ok with it?
CPU is i7 920 D0 Stepping (SLBEJ)
MEMORY is Patriot PVT36G1600LLK DDR3 1600 Mhz
2. Can I have a "passive" cooler in a mATX case, no fans etc so totally totally silent? If so which ones?
3. What PSU should I get? Bear in mind there could be up to 4 hdd's etc &DVD DRIVE too
4. And finally I think I'd like a case a bit like an amplifier any ideas would be greatly appreciated, but I guess that might be dependant on cooling etc .....thanks!
