Downward pointing ethernet socket
24 Oct 2014
South coast
In the forum archives I came across pictures of an ethernet socket where the cables came out pointing down, not straight into the room. Seems a great idea.
I can't find the post again, or the product on Amazon. Where I can get them? Thanks.
Try searching for angled rj45 wall plate, seems to give the result your looking for :D
Easy when you know what to search for ;) Thanks @SupraWez!
It didn't give what I'd seen but those look very useful and can be flush mounted. What I'd seen (and now found using your search term) was these:
Used a couple of these in work. Only downside with them is all of the ports are on one PCB. So if one port gets damaged, then you have to replace the whole thing.
Not a deal breaker, but worth knowing. Also a bit more of a pain to punchdown compared to a traditional wall port.
Whatever socket I pick is going to be my first time doing punchdown, so Im expecting much trial, error and swearing.
If you look for Fiber Ninja on YouTube he has a punch down video where he preps all cables by making a loop in the pair rather than untwisting them. It’s probably how everyone does it, but it was a revelation for me! You can get the cable end super-close to the IDC connector.
And @bledd is absolutely correct about those sockets. The cables come through a slot at the back and the IDC is straight so if you’re doing a lot of them, it does take longer. But if you’re only doing a few at home they’re fine.
Can you add a link to this please? The looping part, I've had a look, maybe I'm just dull, but I didn't see, he does have many vids !
'Looping' was quick and easy with Cat5/Cat5e. The much tighter twist and thicker conductors of Cat6 and above make it much less practicable.
I'm leaning towards Cat5e as can't see the need for faster at home, max run is ~30m, and it's easier to work with.
Any good reason to do Cat6 instead?
No reason to do Cat6 ever, it has basically zero benefits over Cat5e. Cat6a however is a different story.
Because one day, you'll realise that you woosed out and you'll regret it. (joking - it's OK to woose out)
In the meanwhile, just to prove that even a 10-thumbed idiot like me can do it...
Just make a little gap in each pair with your fingernail
Force the pairs down over the little humps on the keystone.
Then punch down - bear in mind that the scissor type Krone tools don't work on these. You need a 110 punch-down tool - or a total keystone punchdown tool.
I think that's acceptable!
It does help if you have the mother of all punchdown tools!
