DP 1.4 Bandwidth 165hz 1440p
LiE
LiE
Caporegime
2 Aug 2005
Milton Keynes
Is my understanding correct that in order to run 165hz at 1440p you need to use 8bit colour to avoid chroma subsampling?
So we have some choices:
165hz 10bit with chroma subsampling
144hz 10bit no subsamplling
165hz 8bit no subsamplling
If the monitor supports HBR3 (Gigabyte AORUS FI27Q-P for example) then 10-bit Full Range RGB can be used at 165Hz. Otherwise your assumptions are correct.
