30mins at 70mph with a few pull aways is hardly ragging it.
Indeed, I think OP needs to familiarize himself with the red line a little more often.
Could see the filter temp start to increase, but not by a huge amount and no where near the hundreds of degrees I would expect on a regenRed line....
Was hitting it a few times on sunday, but will be taking it up high tonight and am banning myself from using 5th.
Ran data logging on trip home and oil deg went down by 5% almostCould see the filter temp start to increase, but not by a huge amount and no where near the hundreds of degrees I would expect on a regen
Something is deffo amiss with the motor.
it can depend on the actual dpf regeneration cycle. Some cars have to me on a motorway at around 50mph in top gear for around 10mins to actually start the cycle off and at a higher speed and revs wont initiate the cycle. Others inject more diesel in the system to heat up the dpf more, others relie on the car to be driven hard to get the dpf hot to start the cycle, and others have an additive thats added to the fuel every fill up to allow it so go through and heat/clean the dpf.
Also never forget that the dpf is a serviceable item and will need replacing.
And also removing the dpf will now fail the mot.
Yup that is true, does make me think that one day Vosa might then cotton on and say that if a DPF is fitted, then no soot should be emitted on the smoke test, and if it does then it would fail.
won't surprise me if they do that.
The engine probably has another fault that is causing it to smoke a lot and blocking the DPF quickly with the ECU continually starting regens to clear it
Temp was read after engine was warm. Current blocking percentage is reading 34 now which should be below the level for having the light turned on....think summat is borked
Yup removal is mot fail.
taking it off and smashing the insides out then mapping the car to act like it's not there is not an mot fail![]()
This thread is why DPF suck.
Ironically EGR which reduces NOx causes more soot which then blocks the DPF
