Drain port Help
31 Aug 2009
Hi guys and gals.
I am shortly going to be putting my first water cooled pc together and I feel it might be a good idea to put a drain system port in the mix.
But here is my problem and wonder if you people could help me out. I am struggling to see in my minds eye how this would work. I know it should be at the lowest point of your loop. But I will have a 240 rad in the bottom of the primo. this does not have any extra ports on it I could use, so was thinking of building off one of the ports.
But here is my next prob, I am finding it hard to spec the parts I would need so could someone spec me the parts I would need for the drain system. I will be using 16mm/10mm tubing and associated compression fittings.
Ta
I just use a combination of a Koolance Quick Disconnect & a T piece fitting on the lowest point of the loop (a radiator).
Seems to do the job well enough
This ^, which is what i do, or a cheaper option is to use a T and a fitting with a piece of tube with a drain plug and just tuck it away.
