Hi,
We live in a detached house however both our front and rear gutter spouts run into drains on next doors property, along his side path.
He is an elderly widower and has recently been in hospital with cancer. As a result I have been managing his house, cutting lawn etc. I took the opportunity to look at the drains and couldn't even see the grates I had to remove a whole builders bucket of soil just to show the tops of my drains and the a further bucket to clear the first straights of the U bends. I unblocked two of his drains too.
The rear drain is now flushing water away nicely. The front one is blocked
it appears roots are within the drain as I can feel them placing my hand in and around the u bend. Therefore it's blocked well and truly under ground. I have tried flexible rods, jet wash adopters and sulphuric acid. All have had no effect.
I have called the utility company and they stated they will be out within 12 hours.
Who's responsibility is the drain deep underground?
it appears roots are within the drain as I can feel them placing my hand in and around the u bend. Therefore it's blocked well and truly under ground. I have tried flexible rods, jet wash adopters and sulphuric acid. All have had no effect.I have called the utility company and they stated they will be out within 12 hours.
