If using a valve you will actually need to an extra 4 barb/compo fittings to be precise, 3 for the T fitting and one for the female thread on the valve. Don't know of any valves which come with a barb on them by default. Would be cheaper to just use a bung.
Personally I don't like drain lines, they spoil the look of a loop. I drain out of the bleed screw in my rad, with a convenient hole drilled in the bottom of the case. Prior to this I considered siphoning out of the res.
Tube in res, squeeze and watch it flow. No fuss.I don't think it's any great hardship to remove the CPU block then pull a tube off that and drain. Although on saying that.... I can't employ that technique in my new build![]()
Should've maybe thought about that!
Can you show me a picture of that mate?
I was thinking of doing that as I could just quick disconect at the low point in the loop pull the tubing out of the side of the case then connect the other pipe with the mail fitting and then allow it to flow?
So the male part of the disconect with seperate hosing is just a seperate piece you attach when draining right?
This seems like a much simpler solution then installing a T fitting with other parts.
