Draytek 120 and Asus 87U problems
I cant see above, when I try to log into the utility it doesnt "see" the programme. I am however trying what bremen suggested above now (writing this on my phone - thank god for 3g!) and will report back in a minute to see if I can log in to router
0.0.0.0
For what you're trying to do you don't need a default gateway. You just need to enter the IP address and subnet mask. Leave everything else to look after itself.
So you just need to enter 192.168.2.100 and 255.255.255.0
Right made some process using above but having clicked verify afterwards it say "connection is broken" network gateway is accessible but windows could not receive traffic from the internet. I am using same cables as just before on netgear when it was working..
It won't let me log in either though?
Just to check on the digit 2 in the IP address. There is actually space for 3 digits in that third group, so I assume I just type 2 and press tab as opposed to 002?
I'd assume you have multiple network interfaces configured (not necessarily all Ethernet). Try disabling everything except the Ethernet port you're using to connect to the DrayTek.
Ok that got rid of that but same old problem. Its this 651 error. Finally got through to plusnet and they said they couldn't really help, but confirmed it was a "registry" issue. Now thinking of getting fibre just to avoid these issues...!
