Draytek enable web config???
30 Jul 2005
Midlands
hello I got a draytek 2820n the web config has been turned off but I can use telnet to get into it fine. anyone know the command to enable the web config again?
I've had this before when the web interface hasn't been turned off. Sometimes you have to access it via a port which I can't remember right now. However a factory reset should resolve this if you're OK losing your settings.
cant factory reset it, its got too big a config on it to loose. I tried the web ports 80 and 8080 but no luck, only telnet works fine but is limiting on what I can do.
any other suggestions?
may have to phone draytek support tomorrow
You can't turn the web UI off as far as I know, only change the ports or turn the web UI off for remote access.
Try scanning it for open ports from the LAN side.
