Draytek Vigor 2860 upgrade PSA
1 Apr 2014
Aberdeen
There's a new firmware update (3.88) available to fix the latest vulnerability. Unfortunately, if you check for updates within the router, it will list four, none of which work with BT Infinity. You need to go to the UK website and download the BT update.
Yes, I did find this out the hard way.
