I need to replace the washer and O ring in a dripping hot tap in the bathroom. There are isolation valves under the tap but they're plastic and hard to turn without stripping the slot. So, can I do this?
Turn the combi boiler off,
Close the main stopcock under kitchen sink,
run tap until the water stops,
replace washers and O ring,
turn stopcock back on,
run tap until water flows,
turn boiler back on and done?
How long will it take for tap flow to stop?
Any help is appreciated, thanks.
