drive cloning
23 Feb 2004
Greenside/Tyne & wear
I'm getting a crucial m4 64gb ssd and I want to clone my current drive instead of reinstalling everything. Can someone recomend free software & a few pointer on how to do it.
thanks
kev
Personally I'd recommend doing a fresh install, but if you really don't want to then I found this free disk backup and clone software the other day. Its very simple to use and completely free for home and small office use.
http://www.todo-backup.com/products/home/
After you've migrated from your old HDD to your SSD there are a whole lot of tweaks you can do, and some of which you will need to do to make it work properly. I assume you're running windows 7? And also do you know what mode your SATA controllers are in right now? Either IDE or AHCI?
I'd definately do a fresh install if you can - for one your probably find that windows is installed in some IDE mode on the old HDD which requires a quick regfix to swap it to AHCI for your SSD.
There's plenty of good pieces of backup software on download.cnet.com/windows/backup-software/ if not.
