Drive order wrong, how to change?
4 Oct 2003
Sheffield, S.Yorks
For some reason the drive order has changed, meaning my IDE drive comes before my SATA, changing the drive letters. Boot order is correct in bios. How do I change it back?
Cheers
if i understand u correct and u are using win2k or xp.. u can do it easily in computer management (disk management) in control panel -> administrative tools.
Needing to reinstall windows, so the problem I have is it's now calling the SATA drive D:, where it should be C:
Not sure why either, was fine earlier !
Cheers
Ive used the workaround of just disabling the IDE drive from BIOS, forcing the SATA drive to be C: and it's working fine. Thing that worries me is what's going to happen when I turn the IDE back on, and why has it gone belly up in the first place?
Grrr, how do I always get myself into these states? :confused:
As long as youve installed windows with the SATA drive as C:\, it shouldn't change to something else(touch wood). As already mentioned you can change the drive letters of non system drives from the disk management section.
