- 30 Jul 2013
Hello yet again!
I have been slowly downloading the drivers I need for my first build. Thanks to members of the forum particularly teppic I have been making some progress. Unsurprisingly however I have a bunch of new questions.
For the Gigabyte Z87X OC motherboard I have downloaded all the drivers except for the USB 3.0. The website has the download but also says a hotfix must be downloaded as well. Unfortunately there are three possible hotfix downloads to choose from and I am not sure if all three must be used or one specific driver from the three. These are shown as follows.....
Hot fix
KB2822241 KB2811660 KB2779768
(Improve USB3.0 Device compatibility)
(Note) After installed USB 3.0 driver, please install Hot fix.
Any help as to which of the downloads beginning with KB I should use would be appreciated.
As for the HD7970 cards I am using, there are a few downloads available. Theses are as follows.....
Catalyst software suite
Latest Beta driver
AMD Catalyst application profiles
And one optional download - Hydravision package
I know thanks to teppic that the latest Beta driver is needed but I am not sure about the others.
And finally, all the drivers I have downloaded so far have been saved to the downloads folder in windows. Can anyone tell me what I need to do to install them? The Motherboard drivers have all been binary files. I am not sure that once downloaded that they just look after themselves on a reboot or if they need to be opened/run or saved to a specific location.
Once again many thanks to anyone who takes the time to read through all this and has the patience to reply.
Hot fix
Latest Beta driver
