Driver wont install. Help pls.
2 Feb 2006
Have done a fresh install of xp, cant install my video card driver!?
keep getting this message and dont know what to do. Its a 9800 GTX and im using the newest drivers from the website.
Any help ASAP would be great thanks.
try again be more alert to what your selecting, u may have unmistakenly ticked the selection wrong.
we all make mistakes :-)
Power the machine right off, cable pulled out, the lot.
Try again.
Remove and reseat the card
Try again.
It COULD be slightly hardware related......ie the vga funtionality is working fine, but the GPU aint talking.
Certainly it's more likely to be software, but it's a thought.
Have you installed the chipset drivers - are there any yellow exclamation marks in device manager ? It could be that the chipset isnt all there - so the o/s and driver can't see the card properly.
