Drop down menus
15 Dec 2004
Hi,
As I'm slowly giving up on my other problem, I'm going to leave all the content visible on the page but need to fix two small layout problems. I have uploaded the site here. Now, the menu us fine in firefox but the position of the lower div isn't. If you look in IE, the position of the div is fine but the menu is broken. I think it's something to do with me needing z-indexes but I'm not sure so would appreciate someone having a look for me.
Thanks
Ben
In your navigation CSS, remove the padding bit:
Code:
/* Drop Down Box */
li ul
display: none;
position: absolute;
top: 100%;
left: 0;
font-weight: normal;
border-left: solid 1px #7d6340;
border-right: solid 1px #7d6340;
border-bottom: solid 1px #7d6340;
it seemed to remove the top gap.
If you haven't seen it yet it might be worth looking at the Firefox web developer tool bar:
https://addons.mozilla.org/firefox/60/
it's really handy for issues like this as you can do things like edit the css in real time on any page.
Thanks for the reply. I already have the toolbar- I just didn't know that it could do that :o
Removing the padding has kind of fixed it but there's still a gap for some reason :confused:
Any ideas?
Thanks for the help so far :)
Ben
