 - 25 Jun 2012
 - Droitwich
Hello, Yesterday my 16month old son managed to push my PC of the desk and drop it roughly 1.2m to the ground!
Now ever since this the PC has been running at 52*C idle and 60-65*C max while gaming.
I have just replaced the arctic silver 5 and reseated EVERYTHING but the temp showing via the bios 41*C and coretemp still at 50*C (coretemp used to show 32*C same as bios before the drop.
The only thing i can think of is the fron of the case is slightly come away from the rest of the case and the fan at the front is leaking air out of the case and not in to it.
Could there be any other underlying problem causing the heat problem or do you think its just the case? Im going to try and seal it up with some tape in a minute to just double check but could a drop like this cause the temp readings to become wrong/out of sync?
I have tested everything in the PC and it all seems to be working. (I guess im VERY LUCKY!)
