After having a leak in my car which fingers crossed is now fixed I need to dry the drivers foot well out. Anyone with tips on doing this? Carpet out seems to be the consensus but that appears to be a real pain due to the console and maybe having to cut it(2004 Corsa)? Will a wet/dry vacuum do the trick? Not sure how much it will remove as the padding holds most of the water and not the actual carpet itself.
I live on the main road so getting power to the car is a bit of a no no really, would probably take it to my parents where I can park near the house to get power there. Can hire a vac quite cheap so this was my first plan.
