Caporegime
- 17 Oct 2006
Hi
Building up new setup E6600 and Gigabyte SD3 mobo just about to connect my Sata HDD (Maxtor 200gb SataII 3.0gb) but which socket on mobo do I connect to Orange or Purple and if so which one ? Only using the one HDD . Also on back of HDD I have a jumper setting:
SATA 1.50gb/s Mode Setting and the other J4 (Partial) (thats where jumper pin is on straight from box)
So is this jumper setting correct or should it be on the Sata 1.5gb pins? Am only using the one harddrive. Complete noob as Ive never used sata before
Thanks for the help and your time.
