Where abouts? In between the mobo and backing plate? Or in between the backing plate and case?CompMan said:yes there is shorting use masking tape or a piece of thin plastic.
Doesn't fubar it, will just not work with it on!Sipha said:Seems some people do have the problem and some dont, should i bother using some tape inbetween just incase or risk it when its time to put together.
I presume shorting the board fubar's it ?
Thanks
Si![]()
