DS3 Purple ports
8 Jan 2007
Manchester
I have a P965 DS3 that I am going to use as a home server but it only has 4 sata ports and the 2 purple ports used for raid.
Will the purple ports work in ther normal way if I connect 2 seperate drives to them so in effect I have 6 sata ports?
The P965 DS3 only has 2 raid available ports. Wondered if it's these 2 that can be used normally for single drives.
Yes they can, as said above!! Go in to the bios and set the Gigabyte RAID controller to "IDE" or "AHCI".
