- 10 May 2006
Hey all,
Yesterday, I checked GigaByte's site and saw they released a new bios, F7. So i flashed, loaded safe defaults, edited all settings at before, including the overclock, bam. NOTHING. It restarts, no beeps, nothing. When I reset nothing happens, when shutdown and restart, nothing. So I take out the battery, wait 5mins and re-place it and everything is on normal again. I dont know, when over 300fsb it just wont boot! No CPU beep, nothing. Everything was perfectly fine on F6, was sitting at 3ghz on stock voltages, now it doesn't do the same. Has anybody got the same problem? Any ideas? This thing is really starting to make me angry... I've tried so many things... sigh.
Any help would be greatly appriciated. I've got a DS4, E6400, 2gb corsair c4. Is it me or just a bad overclockin bios, or did I missed some settings which should be disabled/enabled?
Edit:
I'm about to flash back to F6 and see if its still there. @BIOS has still a mirror availible with F6, can it hurt flashing back?
Edit:
. You could try pushing your CPU a bit more increasing the volts that is
