- 1 Sep 2005
- Scottish Highlands
Im looking at getting a Conroe/Kentsfield in the not too distant future, and im currently researching all the components I will need. For the Motherboard I think I have narrowed it down to the DS4 or P5B. I like the FSB people are getting wit hte DS3, but unfortunately it doesn't have enough SATA ports or PCI-E x16 slots. So im looking at the DS4 instead. What FSB are people getting with this board? I will be going Phase cooled on the cpu and water cooled on the GPU and NB, so I really don't want to end up being FSB limited. As for SATA ports, I will need a minimum of 7. The DS4 lists 8, which I can see, but the P5B lists 6 on the southbridge and 1 on the JMicron® JMB363 PATA and SATA controller. I can see the 6, but not this extra one. Whereabouts is it located? Also how easy is it to remove the heatpipe coolers, so that I can fit waterblocks? Finally has anyone run either of these boards under Phase? Ho do they perform? And are there any other options I should consider?
Thanks.
Thanks.
