DSL Linux Mini USB Key Installation How Too:
All -
I've modified the Mini How-Too and created a PDF which has the screen shots I used for the installation < all via VNC >. I will post the txt version here when I've got it properly formated. In the meantime, you can download the PDF version which is about 1.5MB seperately from the distrubution file.
COMPLETED SECTIONS:
1 - Base System Requirments
2 - Getting Your Software & Burning The Boot Image
3 - Preparing the USB Key for O.S Installation
4 - Installing The O/S to the USB Key
SECTIONS UNDER CONSTRUCTION:
5 - Post Installation Testing and Custom Configuration
6 - Folding @ Home Setup
7 - BOINC Setup
8 - Tips & Tricks for Using Damn Small Linux
DOWNLOADS
DSL USB Key Mini How-Too.pdf
The Entire Package, Including the The LiveCD Boot Image, The PDF instructions, and a Free ISO Burning Utility can be downloaded from here:
This is a bz2 file.
Linux Decpmpress = tar -xjf dsl-usbkey-mini-how-too.bz2
Windows Decompress: Use WinZip or WinRAR.
DSL USB Key Package < 52.5MB >
INSTALALTION SCREENSHOTS:
1 - cdrecord -scanbus
2 - fstab results
3 - mtab results
4 - lsmod results
5 - lspci results
6 - fdisk - original partition table
7 - fdisk - options menu
8 - fdisk - after re-partition
9 - O/S Install - Start
10 - O/S Install - Sucessfull Instalaltion
POST INSTALALTION SCREENSHOTS:
Installed Applications
Multi-Media & F@H Running
DSL Control Panel & Extentions GUI's
Full Debian Package Installer / De-Installer
Will be adding lots of links here as well.
Stay Tuned !!!
All -
COMPLETED SECTIONS:
7 - BOINC Setup
DOWNLOADS
This is a bz2 file.
2 - fstab results
3 - mtab results
4 - lsmod results
5 - lspci results
Stay Tuned !!!
