CurlyWhirly said:According to your screenshot you are on a 2 Mb service (not 1 Mb)![]()
Nope. The router syncs above the actual speed I get.
I'm a bit confused by thissr4470 said:Nope. The router syncs above the actual speed I get.
CurlyWhirly said:I'm a bit confused by this![]()
So when you go on Max DSL you can actually sync at 8 Mb but for the first few days are limited to 2 Mb then?
I expect this gives RAMBO enough time to work out whether your line is stable at this speed and if so then it gradually increases the speed in 0.5 Mb increments until it comes to a point when your line suffers disconnections and then it stops increasing the speed and reassesses your line again.
CurlyWhirly said:Now I am confused!
Not to worry nothing new![]()
Yeh, they give you a 2mb connection, then shape your connection using radius.sr4470 said:E7 have it like that. Never get the extra speed, no idea why they bothered.
Phnom_Penh said:Yeh, they give you a 2mb connection, then shape your connection using radius.
CurlyWhirly said:So when you go on Max DSL you can actually sync at 8 Mb but for the first few days are limited to 2 Mb then?
tolien said:That isn't particularly significant. What is significant when it comes to thinking about what you'd get with Max is your sync rate - whether you're then throttled to 1Mbps or whatever at your ISP.
Quite clearlytolien said:The Guesstimator isn't always right.
- I mean it said I'd need an engineer visit for 1MBit when clearly I can hit 3-4Mbit without issue. I know lots of people had failed 2MB lines (and the reason BT implemented such a stringent compliance?) but that's their fault for using the consumer fad of USB modems with poor chipsets etc. Oh well, I'm glad Max is here!My stats were accurate as I asked my ISP - in actual fact, they said my Attn was lower than my router reported, I believe they said 45dB Attn and I failed the 2Mbps by 2dB - I'm thinking I've been screwed and they were solely relying on the BT Guesstimator which said, as I've said above, that I'd need an engineer for even 1Mbit - oh well, more reason to migrate from +net.tolien said:It's possible it was wrong (impossible to say without accurate stats).
On the other hand, there weren't many folks complaining about sync loss with the old system (barring a tiny percentage of false greens), and there's a distinction between how feasible the "suck it and see" mentality is with a few tens of thousands and a few million lines...
I'm a bit confused here as if the amount of IP throughput (i.e. download speed) doesn't make the connection more or less stable then what doestolien said:Not even close.
The data rate (which is the 2Mbps bit, and should eventually change) isn't connected to your sync rate (which varies with your SNR margin, and so could change much more frequently).
Changing the data rate doesn't make your connection more or less stable - it just changes the amount of IP throughput you get.
Yes I am glad I upgraded to a router now to take full advantage of Max DSL.smids said:but that's their fault for using the consumer fad of USB modems with poor chipsets etc. Oh well, I'm glad Max is here!
I'm a bit confused here as if the amount of IP througput (i.e. download speed) doesn't make the connection more or less stable then what does
Also does the sync rate change after the 10 day bedding-in period or is it stored in a RAMBO profile somewhere where it never changes again?
In other words does Max DSL continue to be 'dynamic' after the 10 day period or is your line speed fixed after this?
I would guess that your profile is fixed after this time as it would mean less work for BT Wholesale with perhaps only new Max DSL connections being 'dynamic'?
