Dual booting help...
Permabanned
26 Jul 2007
Coventry
I have got Vista home premium 64-bit, and it seems that all my older games like medieval 2 total war, and aoe3 are not compatible.
SO I want to dual boot with xp pro. thing is I have no idea how.
And is it possible to keep my exsisting vista install, or will i have to start from scratch?
how do drivers work over two os's?
Just want some general info on how to dual boot really, pros/cans etc...
Thanks
Yanto.
You need to install a seperate Operating system on a different partition or hard disk.
If you have 1 disk/2 partitions, install XP onto the other partition.
If you have 2 disks, install XP onto the other disk which Vista isnt installed on.
