Dual-Core 3800+ 220w PSU?
10 Mar 2006
Hello guys!
I'm putting together a computer with these componenets:
Dual-Core X2 3800+
ASRock (939NF4G-SATA2) Socket 939
2GB 400mhz DDR
Onboard Graphics
80GB SATA HDD
Windows XP PRO (SP2)
Couple of fans for cooling
NO Floppy
NO USB Ports
NO CD-Rom
However I need to build all of this into this case:
Antec Black Minuet II Micro Atx Case 220w
I know that its only a 220w PSU however I feel it would run fine with that setup, just really need to know your opinons!
Thanks very much
Jason
What CPU are you running?
Personally I woudnt risk it, all your components can blow and its not worth it.
EDIT: Just noticed the CPU in the title, I dont think it would work. but wait for someone elses opinion.
MC_Bob
Since your using onboard graphics and sound, it's possible that the power supply could handle it, but it could get quite toasty. If you can't increase the power supply, then I'd drop to a single core cpu. Have a look on AMD's website for the power requirements to make sure before purchasing.
Jas0n said:
Hello guys!
Dual-Core X2 3800+
2GB 400mhz DDR
Onboard Graphics
80GB SATA HDD
NO Floppy
NO USB Ports
NO CD-Rom
Thanks very much
Jason
Why not buy the arctic cooling silentium line case/psu combo, 450w psu in a stylish case for £50
Probably wants SFF...
So what about the aspire x-qpack or antec aria?
fornowagain said:
Shuttle PSU are well known to be under-rated. i.e. higher power outputs than specified.
Yup. Shuttle PSU's are completely on a different scale to a normal ATX. A 300W shuttle is like a 450W ATX. I've seen them running the most power hungry cards and processors both overclocked.
I would say you will be fine on a PSU around 300W as long as it's not a cheapo £5 jobbie. Stick to decent brands and you should be fine.
I find a good rule is the heavier the PSU the better!
