Display 1 - 17"" 1280 x 1024 LG LCD
Display 2 - 36"" 1360 x 768 Samsung HDTV
I'm having problems usefully utilizing both displays. ATI's extended desktop isn't really that helpful. Is there anyway you can have two desktops, one on each display, and be able to switch between them?
At the moment, if I want to play a game using the HDTV I have to switch it to the primary display and then play the game, which is annoying. Also, when the TV is off various windows always go onto the screen that the TV usually displays, so I have to turn it on just to drag the window back into the LCD's desktop space.
I'm just wondering what people with the same setup have done?
