- 19 May 2005
Before I spend too much time troubleshooting, can anyone confirm if it’s possible to run dual 4060 Ti GPUs for 8 monitor outputs (4 outputs on each card)?
Here’s the setup:
• I’ve installed two 4060 Ti cards in an Asrock B650E TaichiAM5 motherboard, which has two full 16x PCIe slots.
• Both cards are powered by a Corsair 1000W PSU, and they both physically spin up.
• However, in Windows, only one card (the one in the first slot) is detected. GPU-Z also only shows one card.
This setup is for a workstation, not gaming. I plan to test swapping the cards in the first slot, but before I dive deeper, I wanted to check if this configuration is even feasible.
TL;DR: Installed dual 4060 Ti cards in a workstation for 8 monitor outputs, but only one card is detected in Windows. Is this setup possible?
Here’s the setup:
