Dual M.2 2.5" SSD Adapter?
It's for a space limited chassis (HP Microserver). I'm told a pair of normal SSDS will sit in the space, just might need a cable tie or two.
Aah ok, I was thinking maybe laptop and because the Hdd slot in a laptop only has 1 sata connection you wouldn't be able to do it, looking at the 3.5" couldn't you remove the mount and just use the board in the 2.5" bay held in with velcro or cable ties?
