Dual monitor arm which sits flush against wall?
27 Mar 2004
Devon
Hi,
Bit of a odd one this but just seeing if anyone can suggest anything. Bought a cheap dual monitor stand from Amazon and set it up today. I have a 27" and a 24" monitor and Like them pretty much flush together and as far back to the wall as I can get them. I'm really limited on space in my little man cave. I was hoping that getting rid of monitor stands would make the desk more open but I seem to have an issue with this monitor arm in that if I want the 2 monitors together then I have to bring them forward on the desk because I can bend the arms back as the wall is blocking it. So really I need the arms to be shorter. Does anyone know of any arms that might be better suited for this? I will probably upgrade the 24 to another 27" at some point but even then its still going to leave a gap in the middle with this stand. I was hoping for a pretty clean look.
Included a couple of pics because I probably haven't explained this well.
It's probably best to get two separate stands.
I don't think I could use arms as I would still have the same issue. Probably single poles if that's something they make.
PROPER AV Premium PB110 Double / Triple Monitor Desk Mount
Just had a look at this. Would be spending more than I wanted to if we are seeing the £60 price. It's also really wide but I could just chop off some of it on both sides. It does say it has pivot, tilt and extend which I couldn't tell how from the photo. Might have to be something like this. Thanks for that suggestion.
I grabbed a similar copy on ebay used for a tenner and trimmed the length to suit.They work really well they don't extend though so don't know why they said that but are adjustable with allen key.
I bought this from a competitor and cannot fault it. Currently have 2x27" monitors.
Xenta Wall Mountable Full Motion Dual Monitor Mount for 13-27inch | Gas Assisted Double Arm Wall Mount
Ah yeah good shout I could try ebay.
Rented so can't wall mount :(
If you search the net for "AIMEZO Dual Monitor Mount" you'll see what I bought. Because it comes in pieces to put together, I was able to just leave out the middle section of the arms, which meant I could mount my 32" monitor and my 24" next to each other, with no gap and pretty close to the wall.
