Hi all, hope this is in the right section.
Just built new pc, cheers for help on here, very happy with it! but...i have the weirdest issue and i needs help!
I have a Radeon 5700XT, 34" main monitor and 24" second monitor
Both monitors work perfectly, but only when one is plugged in. If i have both plugged in one goes black screen (power saving mode) even though its showed the startup screen, it seems to be once its got to windows. The screen is there as you can move the mouse over to it, even dragging open windows to and from it.
Main screen is plugged in using hdmi
second monitor is plugged in using display port
Both on the graphics card
Both monitors have the correct drivers and are displayed in AMD software and in windows
Even though pressing detect it says cant detect another monitor, it shows both
I cant seem to switch the 24" monitor from 1 to 2 in windows for some reason, even though i have set the main monitor as the 34" it still shows as number 2
If i only plug one monitor in it works, this is the case for both monitors
Everything 'seems' to be right but this second monitor going into power saving mode once in windows
Never had an issue before but as i say its a new system, please help
