dual motherboard case
  • Thread starter Thread starter Deleted member 6068
  • Start date Start date
Deleted member 6068
Deleted member 6068
I'm looking for a case that has room for 2 otherboards as i'm wanting to mod my xbox 360 into the same case as my pc.
I have done some looking around and have found the thermaltake mozart 1000 mediacentre case which has mountings for two motherboards but would like to find others before i buy the mozart.
thanks
steve
Digipro - can you explain why please - I am very new to all this and don't understand why you might want to - having never even seen an XBox I have no idea what it does that a pc doesn't, so what will it do for you ?
Sorry if this is a dumb question but then again, it is what I do best... !
If you dont ask you dont get my friend lol.
I just want to have them mounted in the same case thats all and saves on space plus it would be cool thats basicaly it lol
Not seen an XBox!?
I meant in the flesh - I live in a place where we have no landlines, no mobile signals, and internet is via a microwave system that works some ofthe time - as for broadband - Ha - maybe in 5 years or more...!
My local supermarket is a 40 minute drive away, and I drive along the riverbed to get to the road.
Games are things we use a few stones and a bit of cactus to play..
Digipro - thanks - makes some sort of sense now !
Not sure you need a massive case to do this. A 360 is pretty small, I'd be surprised if it didn't fit, case and all, inside my akasa eclipse. How full is your current case?
A good wide case like the eclipse is a very good alturnative to a twin mobo cases.
As long as the graphic card is not oversized or in a low pci-e slot.
Might need to cut up the case to give it a lower profile or even mount the board on the side panel of a hinged door.
The Zalman GT1000/900 range comes to mind (but don't know if the hinges are strong enough.
Or you could try the Thermaltake sword / Tai-chi cases these can have watercooling attached to the door
(but are available without) Not really a 'quality' case but will be man enought for the job.
