Dual screen wallpaper problem
18 Jan 2007
Land of the Scots
OK so I have dual montiors, both 1680x1050, but I cannot get a dual screen wallpaper to display properly, when I choose tile it decides to tile it twice on each screen even though the image is bigger than both screens!
here's the original image;
and the result, I don't get it, I've done this before.
Any help?
Download Ultramon, good little program, you can then set it to span a single wallpaper or set seperate wallpapers for each screen :)
yeah windows cant do that
Ultramon is a must for dual/multi screens also gives you a taskbar on your other screens too
you don't need any special programs to do that, save the image first, in say my pictures, then browse to it and set it to tile mode.
if you use your web browser to 'set as wallpaper' then it won't work
I use Display Fusion for multi screen wallpaper handling ... seems to work ok and is free, (there's also a pro version which does additional things I don't need)
