Dual View Wont Work :-(
1 Dec 2003
Lincs
Hi everyone i rescently bought a 19" widscreen tft to go with my normal 19" Lg tft. The widescreen is mainly used for tv and dvd and the normal one for my pc.
Howeveer my computer wont let my use the Nvidia dual view so i can maximise a DVD in the one monitor. The option is in the nvidia control panel but the screen just flickers and it returns to the previousy selected option.
The computer will howerer let me use the two together as a stretched horizontal monitor but this is pap as if you maximise a window it stretches across both screens and the resolution is wrong for the widescreen.
I am using the latest forceware drivers i hear there may be problems with the dual view with these form a google search. Both monitors are VGA and one is using a DVI - VGA adaptor.
Any thoughts? Or help?
