ducky shine info
18 Jan 2014
United Kingdom
Im interested in getting my first mechanical Keyboard and i was looking at the Ducky shine 3 TKL, but ive noticed in reveiws on U-Tube they have a snake as the space bar, but the ones on overclockers pic previews they have the Duck, does it come with two space bar keycaps in the box.
they come with 2 spacebars I have a shine 3 TKL and use the normal ducky space bar
Would it be worth waiting a little while. I thought they were working on the Shine 4 atm.
ive only seen the non tkl one of the shine 4, and i dont like the knobs on the top right, which is only my personnel preference, others might like it.
ok great, i wasnt sure if it was something you ordered seperately.:D just want some red and white backlightable keycaps now.:)
no TKL shine 4 announced No date for the shine 4 AS soon as we know you will know
ok, so if im using it for games and some typing emails etc etc are red or brown switch better, i have looked at reviews and people are saying browns for both is this correct.
I use browns and love them.
Browns have a very slight bump when activated which helps with both gaming and typing so you now youve activated the key without looking its nicw to know its a lack of mana or skill points stopping that skill working and not a funky key press. The only issue I have is they are a little light so releasing fully for say double jumps can take a bit of getting used to
id like a switch with a little feed back, so it sounds like the browns, thanks for your input, just looking for back lightable keycaps now before i buy, only 2 duckys in stock so best be quick.:D
I use browns at work they are ok but the red's are my preference. I do however use Orings on my reds at home.
dont think you have red switch red LED in stock, but do they def do come with the snake space bar.
All the Shine 3 series keyboards come with the two spacebars, Snake one comes on the board and the Duck is lose with the red WASD keycaps.
If I remember correctly the stock images for the DK9008S3 has the Snake and the DK9087S3 has the Duck.
Initially only the limited edited Year of the Snake model was going to have the Snake spacebar but it showed of the RGB lighting better than the standard one so in the end all models got both.
thats good as i didnt think it suited the ducky style and the shiny plastic bits, matt black so much better, any news on the sine 4 tkl, and when can we expect to see a production model on these.:D
TKL normally come quite a while after the full size models, but as the full size doesn't have an exact date yet that doesn't help you a lot :D
